09-25-2018
04:46
06:42
SantiR
09-25-2018
04:46
06:42
SantiR
So after I have used my ionic to do a workout or a weights workout . The summary always has the distance I’ve traveled and my pace . Both which are irrelevant to the workout / weights session I am doing. Is it possible to change these to duration of the workout and heart rate? Thank you 😊
Moderator Edit: Updated Subject for Clarity
06:38
10:20
09-26-2018
06:38
10:20
@Staceymcxoxo Welcome to the Fitbit family! Thanks for taking the time to post your inquiry about the data shown on your Ionic's exercises.
When selecting the Weights or Workout exercise on your Ionic's exercise app you should see a gear icon on the top left corner. When you tap it you should find some settings; find "Customize Stats". Right there, you will see 3 options: top stat, middle stat, and bottom stat. Tap them accordingly to select which stat you would like to see for your weights or workout exercise. Heart rate and elapsed time should be available for you to select.
Hope this helps. Try that out and let me know how it goes! ![]()
09-26-2018 13:17
09-26-2018 13:17
Best Answer09-26-2018 21:31
09-26-2018 21:31
Hi, @Staceymcxoxo! Unfortunately, this has been a bug for quite some time. However, at least with Android, this seems to have been updated with a recent app update. Have you checked to see if there's a new app update?
MakMak | Community Council
