12-28-2017 03:20
12-28-2017 03:20
Just curious to know that since the Ionic is equipped with GPS if you were to lose the watch, not just at home. Would you be able to track it’s location with a phone or a computer?
Best Answer12-28-2017 11:53
12-28-2017 11:53
There are apps on Google Play and the App Store to find your FitBit device but they all work on Bluetooth and not GPS, which will severely limit the area where the signal could be picked up to be of any use.
12-28-2017 03:33
12-28-2017 03:33
@cstiehl77 wrote:Just curious to know that since the Ionic is equipped with GPS if you were to lose the watch, not just at home. Would you be able to track it’s location with a phone or a computer?
Okay I'll say what everyone's thinking.... stalker!
Just kidding lol. That's actually a good question, since it can be done on virtually all phones.
12-28-2017 04:23
12-28-2017 04:23
The watch itself would need to "transmit" the GPS information it is receiving. It has Bluetooth and WiFi capabilities. But you would need to lose the Ionic within range of something that will "listen" to it. (Either paired Bluetooth or connected WiFi network)
12-28-2017 11:53
12-28-2017 11:53
12-28-2017 14:36
12-28-2017 14:36
Findmyfitbit works nicely, but you need to be within about 50 feet of the tracker.
Now of you download the app ahead of time. Should the tracker get lost, this app will tell you when am where the phone lost cominocation
Best Answer05-03-2019 22:25
05-03-2019 22:25
Surely the device should be able to be tracked by the device ID & GPS?
I don't understand why there isn't a service to search for the last report of the device, regardless of whether it is synced to your phone
05-04-2019 02:41 - edited 05-04-2019 02:44
Yes and know @lowdon , the device only turns on the GPS at the request of the user, and unless the ionic OS code enough to the phone it will not be able to combustibles with the Fitbit server.
Wyatt would work is if the lousy tracker could be flagged and have various phones with the Fitbit app ping for the device when it is close to the area of the last sync.
Best Answer05-04-2019 15:16 - edited 05-04-2019 15:17
From your posts, I have the feeling that you think that GPS transmits, it does not. It is a GPS receiver, as are the ones in phones, cars, etc.
For that received data to be seen elsewhere there needs to be a radio involved (phone, Bluetooth, etc.)
In short, unlike multiple misrepresentations on TV, you can't track a GPS.
