01-23-2019 19:01
01-23-2019 19:01
My Ionic has suddenly put the word “fined” on my screen, in red, twice.
Why, and how do I get rid of it.
Best Answer01-24-2019 06:38
01-24-2019 06:38
I had the same problem. After trying a restart I contacted support. They had me put it on the charger again, change the watch face and then sync it. That cleared the message and I was able to change back to the original face. If that doesn’t work for you, I’d try contacting support.
01-23-2019 19:36
01-24-2019 05:24
01-24-2019 05:24
Did you sort this problem out as I got same thing as I took watch off charge last night
01-24-2019 06:38
01-24-2019 10:29
01-24-2019 10:29
Best Answer01-27-2019 21:23
01-27-2019 21:23
Thanks for your solution. It worked on my Ionic.
Cheers!
Best Answer01-27-2019 22:32
01-27-2019 22:32
I noticed that on mine as well. I changed the clock face and synced it but today it started restarting itself over and over again. After talking with support I learned that there is currently some issue with Ionics and Versas not connecting to wifi properly and not updating. Mine is now stuck in setup and I can't even properly do a factory reset on it because it says Data Not Cleared Sync and try again, but I can't sync! Very frustrating.
