09-30-2017 05:03
09-30-2017 05:03
I have looked up every way and done everything to try and update my Ionic with the new firmware...Nothing seems to be working....I've unpair....factory rest...turned phone Bluetooth on and off.......etc....not sure what it is I'm missing or why it won't update. All I keep getting is the X and update fail....any ideas or suggestions?
09-30-2017 05:07
09-30-2017 05:07
Hi, I did a factory reset, then with the Fitbit App on the iPhone setup new device, replace former device.
and start all over, step by step, you get a question for the wifi netwerk and it will update the watch again my case.
Best Answer09-30-2017 05:14
09-30-2017 05:14
Thank u will the factory rest again I have a Samsung Galaxy note 4.......it didn't work the first time...it's so aggravating
09-30-2017 05:17 - edited 09-30-2017 05:45
Try with your mobile, I just added it with the + symbol to my fitbit device list in the fitbit App and it was seamless. Make sure you have properly connected to wifi directly to your Ionic in the initial set up procedure. The update takes about a half hour so be patient. There will be a blue wash that moves from left to right over the fitbit logo to show your progress.
During setup, you’re prompted to connect Ionic to your Wi-Fi network. Ionic uses Wi-Fi to download playlists and apps from the Fitbit App Gallery, and for faster firmware updates.
Ionic can connect to open, WEP, WPA personal, and WPA2 personal Wi-Fi networks.
(Your Ionic will not connect to 5GHz, WPA enterprise, or public Wi-Fi networks that require logins, subscriptions, or profiles)
If you see fields for a username or domain when connecting to the Wi-Fi network on a computer, the network isn’t supported. For best results, connect Ionic to your home or work Wi-Fi network. Make sure you know the network password before connecting.
If you have already setup your Ionic and want to run the update, you can ADD the Wi-Fi network you are connected to from your mobile’s fitbit app:
1. From the Fitbit app dashboard, tap or click the Account icon () > your watch tile.
2. Tap or click Wi-Fi Settings.
3. Tap or click Add Network and follow the on-screen instructions to connect your watch.
Your Ionic will have a green check mark pop up on its face and vibrate briefly to acknowledge the connection has been made.
If you have already setup your Ionic and want to run the update, you can CHANGE the Wi-Fi network you are connected to from your mobile’s fitbit app:
Plug your watch into the charger (when there are 2 or more Wi-Fi networks in range, you can choose the network your watch should connect to)
2. Tap or click Wi-Fi Settings. Wait a moment for the list of networks to appear.
3. Tap or click the network name and then tap Connect.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
Best Answer10-05-2017 12:29
10-05-2017 12:29
I am having the same issues with updating my Ionic on a Note 4. The WiFi will not connect at all. It constantly fails to connect to WiFi. Did you ever have success?
10-05-2017 13:51
10-05-2017 13:51
What is the latest firmware? Mine is on 25.16.7 but I keep seeing 30.3.2 being discussed out here and when I sync, I'm not getting the indicator that there's a firmware update. ???
Best Answer10-05-2017 13:57 - edited 10-05-2017 14:03
@taz4352 wrote:What is the latest firmware? Mine is on 25.16.7 but I keep seeing 30.3.2 being discussed out here and when I sync, I'm not getting the indicator that there's a firmware update. ???
I think the latest firmware update are for those in Europe and for those of us in the US we still have the 25.16.7 version. There is also the developer beta firmware updates if you signed up as a developer with the open SDK.
We discussed the Europe and US versions in this thread Oct 4th Firmware What's new?
Best Answer10-05-2017 13:59
10-05-2017 13:59
mine says 27.30.3.2 but I have developer app - that may be the difference you are noticing 😉
WmChapman | TX
Best Answer10-05-2017 14:02
10-05-2017 14:02
Thanks for the info.
10-05-2017 18:10
10-05-2017 18:10
I have recorded my 12th attempt (and fail) to get my firmware updated so I can share with the support team. I am using a Note 4 in this video which is listed as a compatible device. I am beginning to think the watch I received is a lemon. https://youtu.be/uBEA9taiSww
10-06-2017 16:39
10-06-2017 16:39
Fitbit WILL NOT CONNECT TO WIFI. This is my 17th try. I have restarted/rebooted/reinstalled EVERYTHING. This is getting quite ridiculous.
10-06-2017 17:53
10-06-2017 17:53
I don't know if it'll help but when I was setting up my Ionic I encountered failed 5 times. I read somewhere in the forum that you will have to really position both the phone and Ionic right next to your router in order for the wifi setup to work. I did just that and it went through (the setup and the update).
Best Answer10-07-2017 04:13
10-07-2017 04:13
I reached out to support and they gave these steps. They didn't end up working for me and after responding back that it didn't work, support didn't have anymore idea.
Unfortunately, my only option is to return the watch. 😞
SUGGESTIONS FROM FITBIT SUPOORT
In order to further assist you, we will kindly ask you to follow the steps below:
Remember, Ionic can connect to open, WEP, WPA personal, and WPA2 personal Wi-Fi networks. Your watch won’t connect to 5GHz, WPA enterprise, or public Wi-Fi networks that require logins, subscriptions, or profiles. If you see fields for a username or domain when connecting to the Wi-Fi network on a computer, the network isn’t supported.
10-07-2017 04:22
10-07-2017 04:22
The firmware update that was released last week is best loaded onto the Ionic using BLUETOOTH. I had NO issues using Bluetooth!
Wi-Fi on the other hand, is best for the music upload to the Ionic.
Gunny | Richmond, VA (USA)
Ionic Adidas Edition, Versa Special Edition, Aria 2 & Flyer | iPhone & Windows 10
Take a look at the Fitbit Help site for further Assistance & Information.
Best Answer10-07-2017 11:03 - edited 10-07-2017 11:04
Just an idea:
try a different WiFi network.
i have no problem with WiFi, so hardware of the Ionic is ok. I saw on tube a demo About not connecting to WiFi. And the Fitbit and Ionic got the blame, but to be honest:
the time that the phone needed only to find WiFi was terrible. A bad WiFi network. Try Some network with your friend before come to conclusions
Best Answer10-07-2017 13:50
10-07-2017 13:50
Yeah...so I tried 4 different Wi-Fi connections...
Have heard that Fitbit might issue a recall for Ionics purchased during release until 5th October? Has anyone else heard something similar?
Best Answer10-07-2017 15:22 - edited 10-07-2017 15:23
I returned my first Ionic because it would not sync (put it in the mail to Amazon today). I was going to wait for the credit back into my account, but I ended up giving in and visited the local Target to pick up another Ionic.
I took it out of the box and quickly synced it up in the same way before. Everything went flawlessly. I will see how long it lasts, but the returned Fitbit most definitely had an issue connecting to WIFI and syncing.
10-20-2017 09:22
10-20-2017 09:22
That's odd - I didn't have any problems at all. I assume your ionic is plugged in and can normally connect to your phone?
Best Answer12-21-2017 22:20
12-21-2017 22:20
Is blouthooth is really working for the firmware update ? I am completely give up for the WiFi update and errors -WIFI fail !!!
Best Answer12-27-2017 14:19
12-27-2017 14:19
I have an iPhone 6s and a Fitbit Ionic. I went into setting on my phone and removed the Ionic from Bluetooth. I went to the Fitbit app on my phone and it told me there was an update waiting. I updated it from there and the firmware updated successfully.
