09-21-2017
02:44
05:36
AndreaFitbit
09-21-2017
02:44
05:36
AndreaFitbit
i'd like to ask a question: Can I leave my iPhone 6S plus at home, go out and train and later synchronize with Runkeeper? I'd like the new IONIC to have this feature that is very important for me to evaluate the purchase of the device. thanks 🙂
Moderator edit: subjects format.
Best Answer09-22-2017 02:01 - edited 09-22-2017 02:04
@gtoni70 wrote:thans for your reply but i'm very confused … in the runkeeper profile - account setting - under "runkeeper mobile app", i can see "Fitbit -> connect to fitbit"
Sorry I was mistaken. As @bbarrera said, the sync between fitbit and Runkeeper doesn't include GPS data, heart rate etc.
Im not sure if this would work or not, but you could try linking your Fitbit account with strava and then linking your strava account to runkeeper and see if that preserves all of the data. I know the fitbit to strava sync definitely includes GPS and heart rate data, but I'm unsure what data the strava to runkeeper sync provides as I don't use runkeeper. I know it's a bit messy but worth a try if you are looking for an automatic sync.
Good Luck.
Edit - To answer your question, you would click that connect to fitbit button to link the two accounts. When you click the button it will prompt you to log in with your fitbit credentials, then it will ask for various permissions.
09-21-2017 04:21
09-21-2017 04:21
Yes. The Ionic has built in GPS so you don't need to carry your phone to track your workouts. You can also "connect" the Runkeeper app with your Fitbit account so your activities will automatically sync to your Runkeeper account.
09-21-2017 07:13
09-21-2017 07:13
@gtoni70 The Fitbit-Runkeeper integration does not include workouts:
Instead of using the Runkeeper integration, you would need to manually add to Runkeeper, or if it’s a GPS Run then from a computer you can export TCX from Fitbit and then import into Runkeeper:
https://blog.runkeeper.com/313/easily-import-your-data-into-runkeeper/
Hope that helps.
09-22-2017 00:35 - edited 09-22-2017 00:35
Good Luck.
09-22-2017 02:31
09-22-2017 02:31
thanks a lot 🙂
Best Answer09-30-2017 11:19
09-30-2017 11:19
From a gs8 with an iconic
In the runkeeper app when I goto connected devices and add the iconic isn't discpvered
