06-26-2020 00:44
06-26-2020 00:44
I saw that my fitbit doesn't sync properly so I decided to turn it off. When I did so it showed the Logo then it turned black. After that I couldn't turn it back on again. I tried pressing the big button on the left and the ones on the right and even all together. Nothing helped turn the device back on. My battery was at ca. 65%. I am using the Fitbit Ionic. My sync device is an OnePlus 7 Pro with the newest updates.
Firmware version: 27.70.8.0
06-26-2020 05:27
06-26-2020 05:27
Try holding down all the buttons until it turns on.
06-26-2020 05:27
06-26-2020 05:27
