04-28-2018
21:40
07:15
04-28-2018
21:40
07:15
Hi, My ionic does not start. Have charged it for hours, tried long press multiple times but no success. Mobile app is also not able to find the watch. A help to resolve would be greatly appreciated.
Try restarting it several times. If that doesnt work you will need to contact Support (link in my signature ) or return it to the store it was bought from.
Helen | Western Australia
Welcome to the Fitbit Community @NellyG, hope you're doing great today! Thanks for restarting your Fitbit, nice way to go! Are you still having issues to set up your Fitbit Ionic?
If you can't get started with your Fitbit device, usually a missing requirement is the cause. If you're using the Fitbit app for iOS, Android, or Windows 10:
If after checking the requirements you are still having issues paring your trakcer, try the troubleshooting steps below:
Thanks for your help @NellyG!
Give this a go and let us know the outcome!
I did all you said! Only crashed after last update: was losing 15mins/day. Resulted in factory reset and now unable to load on pc or phone. Only bought it Jan 18 and unable to locate receipt at this moment. 😞 Any more advice?
Hi @JacquiBee1, welcome in here! Thanks for following our tips and recommendations.
This usually happens when you performed a factory reset without before unpairing the device. Usually you should unpair your Ionic, forget Bluetooth (both Ionic and Ionic (Classic)) and perform the factory reset. To solve this issue follow these steps (some of them you already tried, but let's cover everything):
If you can't get started with your Fitbit device, usually a missing requirement is the cause as I mentioned here (make sure to verify each of them).
Best AnswerI followed your instructions and now it won't turn back on! I bought in 9 Jan 19 and am less than impressed! (I had fitbit charge 2 previously) It seems the last upgrade didn't agree with it. I'm currently trying to locate my receipt but I purchased through Argos and have evidence on my account that it was purchased on the above date.
As it won't restart what is my next step please?
Best AnswerAs mentioned on 30/7 I have done everything you suggested and still cannot get the ionic to work. I've tried every night this week. Please advise what details are required in order for me to return this for either repair or exchange.
Thanks Jacqui
Best AnswerRebooting my phone and restarting the Bluetooth pairing worked for me. Thank you,
