I've had this watch four days now, I've updated my iOS, the watch firmware, the app. I've checked all the settings, on day 1.it wouldn't connect at all then days 2 and 3 it worked as a blaze would (no notifications from apps and no apps would install properly then today it's stopped syncing altogether - it won't connect to wifi either - its driving me mad, can anyone help please
It's great to have you here @Juliesooty. Let me help you resolving the syncing issue you're having. I would like you to try this troubleshoot in order to properly sync your Ionic.
- Are you receiving any error message?
- What's the iOS device you're using?
Hope this helps! Keep me posted.
