Fitbit ionic won’t turn on
ANSWERED
After a run I took my Fitbit off. When I picked it up it would not respond. It was fully charged before my run. I put it on the charger and it is not responding to that either. I have tried to rest it but it does nothing. Only had my Fitbit a little over a year. Really disappointed if it is dead already since it cost so much money.
1 BEST ANSWER
Accepted Solutions
@StevenRDavis wrote:
It seems my vibration intensity is weaker than the original settings.  How do I increase the vibration intensity?  I don't even feel texts or calls, which is very important to me.
Hi @StevenRDavis,
Go into the Settings on the watch. There you'll see Vibrations. Just switch it to Strong, and you'll have a more intense vibration. Hope this helps.
Work out...eat... sleep...repeat!
Dave | California
31 REPLIES 31
Hi @StevenRDavis,
Dave | California
Thanks @WavyDavey for reminding us this is possible!  Also you might like to vote for this feature request.  Be sure to add in the comments that you would like to see this specifically for the Ionic.
Hero, better, thank you!
Moderator edit: Removed personal information
Thank you, it did help.  Hero status for you!
I don't see vibrations in settings.
love the upgrades and yet: even the stronger setting, at least for my unit isn't very 'strong' at all; was stronger before os upgrade on the ionic just days ago.
they have normal and strong option on watch, but they are about the same and both are barley noticable
it would help if they let you set the length of the notifications and\or the pattern of the notifications
but it seems this has been a tough issue for the developers of this watch as it's been a issue for a long long time, and not just this watch, but there last  couple watches they have released, course they just bought pebble, so maybe the new developers will bring in some new talent and they will finally solve this one someday soon
I do not see the vibration settings on my watch either. Once the upgrade went through my Ionic won't wake up when I lift my wrist and I get no vibration notifications at all - not even when I use the timers. The settings on my watch are "tips & ticks" and "inspiration". Any ideas? I've also looked for the settings online and I don't see them online either. STUMPED and unhappy.
Find your settings on your fitbit ionic, with watch face showing scroll right to left 3X, you should see the settings icon; you'll be able to scroll up and down; scroll bottom to top until you see vibrations, tap on it to change strength of vibration.  You can also start by rebooting your ionic; hold down the single bottom on the left with the lower botton on the right at the same time until the fitbit icon appears; then sync your ionic again from your phone. I had to do this twice to get the vibration feature to work.  Still it is not very strong at all and as an alarm only vibrates once at the time set with no snooze feature which was 10 minutes before I upgraded.  Good luck!
I have reset the watch 3 times and synced. I've u installed the app, reset
watch, synced. Nothing. No vibration, no auto turn on of the watch when I
left my arm.
HmmmWell my initial thought is that you should consider taking it back and having it replaced hope you still have your receipt and it’s under warranty best of luck
Sent from my iPhone
Thanks. They are replacing it.
@JoanFP Welcome to the Fitbit Community! Thanks for your question.
To find the vibration setting please go the the Settings App on Ionic (gear icon). Swipe down until you see "Vibrations" and tap it to change it from normal to strong just as @1worldmus posted above.
@JulianneBerg It's great to see you in the Fitbit forums. Thanks for posting on this thread regarding the vibration on Ionic. I'm very glad to hear that customer support is replacing it for you. Please follow these replacement set up steps once you receive the new unit to not loose any of your previous data.
@1worldmus It's great to have you here. Thanks for your great help on this thread!
@jbender68 I hope you're doing well! Thanks for sharing the features you would like to see in the future. I was making some research on the Feature Suggestions Board and found a couple of ideas that may interest you:
Feel free to vote for the ideas. If these ideas doesn't really reflect what you are looking for please create a new original idea.
Hope this helps. See you around! Smiley Happy
Santi | Community Moderator, Fitbit
Like my response? Vote for it! Also, accept as solution!
Thank you.  That did the trick!
@JoanFP Thanks for your reply! I'm very glad to hear that the workaround helped you out. Hopefully, it will help other users too. Glad that you are back on track now.
Also, take a look at the Discussions Board as you will find a lot of interesting things there. Feel free to post on any thread you want. If you are looking for Fitbit friends to compete with on challenges, check this thread to add some!
My Pebble had several vibration strengths as well as duration, short, normal, long.
Can we make the vibration intensity stronger than the Strong setting? Even on that setting it still is easy to miss the vibration notices.
Thanks
This issue is not resolved. Normal and strong vibration are the same intensity and duration.
Neither can be felt if you are doing anything more strenuous than Sudoku.
Thanks for the affirmation. Hopefully someone will use the API to solve it or fitbit will address it from top down.
