Heart rate not working
 I bought a brand new Ionic last week to replace my charge 2. The heart rate is not registrering at all. I have tried the following things
* Cleaning the sensors
* turning the heart rate off in settings turning the monitor off and on and then turning the heart rate monitor back on.
* I have worn it on both arms at different levels.
* have worn it at different levels of tightness.
The sensor is working but no heart rate is being registered. I have seen this on a number of posts as an issue.
13 REPLIES 13
Try restarting the Ionic by pressing and holding the left button and bottom right button together for 15 secs, let go of the buttons when you see the fitbit logo.
Community Council Member
Nathan | UK
Looking to get more sleep? Join the conversation on the Sleep better forum.
Yes I forgot to list that I had done that too many times
Ok no problem.
The next thing I would try would be a full factory reset. As you mention the lights are flashing, it sounds more like a software issue as opposed to a hardware one. Although if the full factory reset doesn't solve the issue it will then be best to contact Fitbit support
Nathan | UK
Thanks Nathan. Trying that now but it won't even pair with my phone. I will keep trying and contact support if it fails.
If you haven't already done so you may need to go into the fitbit app and remove the Ionic from your account, also go into your phones Bluetooth settings and unpair the Ionic. Hopefully it should pair with your phone after that.
Nathan | UK
unpairing in bluetooth settings worked. thanks mate
Did you get an answer on the no heart rate? Would love to know because mine has stopped registering.....
None of the suggestions worked. None of the data collected by the sensors is displayed on watch after most recent FW upgrade, to v.27.32.10.20. I checked app on phone and all data is being collected correctly.  Turned out problem is the clock face, created by a 3rd party developer as their application updates lag behind FW releases.  Problem solved by selecting a "Fitbit" clock face.
A warm welcome to the Community @anmajojo! If you're not getting heart rate reading on your Ionic, please try the tips posted on this article Why don't I see my heart rate on my Fitbit device?
If you're getting a heart rate reading but it's not syncing, please try these tips Why won't my Fitbit device sync?
Thank you for sharing what worked for you @Gyrokut
Hope this helps! Keep me posted.
Further to my own issue. I received brilliant online support from Fitbit and through a process of testing and elimination, I am getting my Fitbit replaced under warranty. Whilst I was frustrated, there was no angst because s**t happens and it's noboby's fault.
Huge thanks to the support team !!!!!! Everyone is quick to complain but not pat on the back.....
Thank you for getting back @anmajojo! It's great to see that you're sharing the resolution that you got from Customer Service.
Hope you can continue enjoying your Ionic. Don't hesitate to come back if you have any further questions. Robot Happy
Fitbit support is a farce. I have tried to reach them with Chat and they keep login off. I also have no heart rate and band is deteriorating. I get no help at all. EdStJames1
A warm welcome to the Community @EdStJames1. Thanks for trying to reach our Support team.
We have many channels of communication which are Chat, Call, Twitter, Email and Community. I've shared your post with our Support team and they've mentioned you already have a case with them, please continue the communication through email.
