Hi I am a daily Fitbit user now for years and my ionic has stopped holding charge now for the last 3 days. I am using the same functionality, no difference in use, but just now won’t even last the day 😔😩😩.
I’m sitting waiting for it to charge all the time and not out walking on my holidays!!
can you please help?
Wow, I’m having the same issue. For me it’s been a happening for a few days as well.
i have tried rebooting and factory reset with no luck.
i have just completely removed my ionic from my phone (including Bluetooth) but it has still lost 20% of battery in only an hour.
Hopefully there is a fix soon!
I am having the same issue also! Started a few days ago. I didn't change any settings or change any habits. At least mine will last 2 days, but it use to last for at least 4-5 days before.
As a side note, My wife's Versa started doing the same thing last week.
Fitbit, what's going on???
Mine started doing the same thing after the last system update! I contacted Customer service and their solution was a 25% discount code off a new device!
Best AnswerAfter communicating with customer service, they suggested changing the clock face to one supplied by Fitbit. I then restarted my Fitbit and it seems to be working much better now.
I only lost 10% in 24 hours, which is approximately what I was losing previously.
I still find it odd that battery performance changed dramatically without changing any settings.
