01-14-2018
16:58
11:45
EdsonFitbit
01-14-2018
16:58
11:45
EdsonFitbit
I set up the lock pin when I wanted to use the pay feature only my bank is not on the list. Does anyone know how to turn the lock pin off now? I have searched everywhere and I do not see how to turn that off.
Best AnswerI found the deactivating feature on my iPad but not android for some reason but got it done!
Best AnswerHi Debra,
The same happen to me. You have to deactivate the locking feature. To do it just go to the Fitbit app, click on the ionic icon on the top right, then scroll down to the botton of the screen and you'll find a Device Lock option. Just click on it and disable it. That should remove the need to enter the pin.
Regards,
Fran
Best AnswerMy Versa 2 doesn't allow me to deselect the lock feature. Frustrating. My lock screen pops up almost every time I look at my watch and I don't even have any pay features activated.
Best AnswerDid you get an answer to your message about your versa 2 and the lock screen? I also keep getting a lock screen and cant find how to disable this pin feature. I cant use the pay feature and then locked myself out and now I cant use anything. Very frustrating!
Best AnswerHi I have a versa 3 and I removed the pin lock first you have to remove your card and whatever else you have there then go and it will give you two options click the first option then get out and log off and then log back on that's how I removed mine on the versa 3 but you have to log out. Hope this works for you all
Hello everybody, thank you for visiting the Fitbit Community.
Currently, there is a voluntary Safety Recall of Fitbit Ionic Smartwatches.
For more information, please visit this thread.
I am going to close this thread since it is too old, but if there is anything else we can help you with, please don't hesitate to start a new topic.
Have a nice day.
