03-08-2018
02:25
05:15
03-08-2018
02:25
05:15
How do i unlock with my phone, or even remove that so i can swipe my main screen
Hey there @Andy1962, welcome to the Fitbit Community!
Once PIN is activated it will have to be entered once a day. If you enter an incorrect PIN code 10 times, you're prompted to unlock your Fitbit watch with your paired phone.
Try to unlock/reset or change the PIN code for your watch in the Fitbit app:with your phone by following these steps:
Note that after you reset your PIN code, you must add your cards to Fitbit Pay as if you were setting it up for the first time.
If the steps above don't work, please turn off everything that is Bluetooth enabled. Tablets, PC, other phones. Wireless headphones hanging around - power off. You don't want any stray 'signals' effecting this process. Then, remove your Ionic from your phone.
Hope this helps. Let me know how it goes! ![]()
I have removed the Ionic but when I start the Set Up process, I get the screen that asks for a for number code from my phone, which is still locked.
