05-03-2018 22:58
05-03-2018 22:58
Hi, I know there are posts about running cues going wrong but I would just like to know how to turn them on could someone run through the steps on how to turn them on please? Also do you have to turn them on each time you run or does it remember?
Thanks in advance.
Best Answer05-04-2018 00:37
05-04-2018 00:37
On the computer Dashboard click on the gear and go to settings. Click on the device name and scroll down until you see Exercise cues. Use the drop down to set the cues you want for the exercises you do.
Wendy | CA | Moto G6 Android
Best Answer05-04-2018 00:47
05-04-2018 00:47
Best Answer05-04-2018 01:51
05-04-2018 01:51
Here is a picture
To attached your own When replying click on the Camera then choose and find it on your computer. Double click to add and then click done
04-06-2020 07:06
04-06-2020 07:06
This enables the cue to pop up on your wrist - is there a way to make an audio cue come through your headphones? Currently that's only available through the phone/app, as far as I can tell..?
Best Answer04-07-2020 00:55
04-07-2020 00:55
Hello @GCrispyJr ,
unfortunately it is not possible and the long ago created feature suggestion has been labeled as not planned. 😣
