10-04-2017
07:04
12:51
DavideFitbit
10-04-2017
07:04
12:51
DavideFitbit
The battery ran down in my New Ionic. I have it charging but can't figure out how to turn it on. I can't find the instructions any where in the online manual. Also it said it would take up to 78 minutes to update. Getting frustrated and considering taking this back.
Best AnswerI had the same problem. I needed to clean the oval shape indent near battery/dat terminals. Be very careful not to damage them. Once the charger cable was able to be seated properly all was good and ionic started automatically. Hope that helped.
Best AnswerThanks! That helped me a bunch. I thought at first that it was only pressing the first button on the left side but didn't know it required all 3 buttons to be pressed at the same time if its not charging.
Best AnswerThanks. By holding down all three buttons, I was able to turn it on. Grateful. I was beginning to think that I would have to consider it broken. 😀
