Indication of charging?
A question.  When I connect my charging cable, the phone shows that is charging for a few seconds then goes dark.  Is that normal or is there a setting that will keep some display lit to show charging progress?
I'd like something to reassure me the cable is connected and hasn't dislodged.  The magnets are mot that secure.
3 REPLIES 3
The battery charge will show on the Ionic itself when you plug it in. Not sure if this helps or not, but I found out this morning that if you swipe right on the Ionic, it will tell you how much battery is left.
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
I believe this is normal because mine does the same. It shows me the current % of the battery and that it is charging, then the screen goes dark. I can press a button to see what it currently is at, but by design I think it's supposed to go dark
Given that the screen is a pretty large power draw in its own right, leaving it on would be pretty counter productive while charging, likely extending the charge time somewhat.
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
