Just wondering if the IONIC will have the SPO2 Sensor enabled?
Looking at the Versa Features its listed as
WHAT'S INCLUDED:
- Fitbit Versa
- Classic wristbands (both small & large)
- Charging cable
WHAT’S INCLUDED IN SPECIAL EDITION VERSA:
- Fitbit Versa
- Woven wristbands (both small & large)
- Charging cable
SENSORS & COMPONENTS
- 3-axis accelerometer
- 3-axis gyroscope
- Optical heart rate monitor
- Altimeter
- Ambient light sensor
- SpO2 sensor
- Vibration motor
- Wi-Fi antenna (802.11 b/g/n)
- NFC
BATTERY AND POWER
Fitbit Versa has a battery life of 4+ days. Battery life and charge cycles vary with use, settings, and other factors; actual results will vary. We recommend charging your smartwatch every few days to ensure you are always tracking.
- Battery type: Lithium-polymer
- Charge time (0-100%): Two hours
- Radio transceiver: Bluetooth 4.0
MEMORY
- Saves seven days of detailed motion data – minute by minute.
- Saves daily totals for the last 30 days
- Stores heart rate data at one-second intervals during exercise tracking and at five-second intervals all other times
