06-13-2019 09:08
06-13-2019 09:08
So the brightness on my Ionic is always at the most dim/least bright when the Brightness is set to Auto. I have restarted and reset my Ionic. I have tried different watch faces too. The Auto Brightness always goes to the most dim setting.
As stated before I have restarted my Ionic. I have reset my Ionic. I have changed watch faces (to a Fitbit made watch-face). I don't have any apps installed. Manually setting the brightness will change the brightness but I would like to use the Auto Brightness setting.
Any ideas?
Thank you!
06-14-2019
17:28
10:09
06-14-2019
17:28
10:09
Welcome back @FitzTML. Thanks for the details mentioned and the troubleshooting tried.
I would like you to confirm that you've followed these steps to restart your watch. Also, if you have it set to auto then it will change depending on the light of the room. Can you let me know if the setting itself is changing to dim even when you haven't done it or is just the brightness itself in your Ionic changing?
Keep me posted.
Best Answer06-14-2019 17:52
06-14-2019 17:52
I have properly restarted my Fitbit. The Auto brightness will always display at the most dim setting, making my watch difficult (or impossible) to read in bright light. There is nothing that I can see obscuring the front/face of the watch that would block any sensors.
The only way that the watch will change brightness is manually setting the brightness to Normal or Max.
11:37
10:08
06-17-2019
11:37
10:08
Thanks for getting back @FitzTML. Sorry for the delay reply.
Thanks for confirming that you've followed the restart instructions. I've shared your post with our Support team, they will continue assisting you.
Best Answer07-01-2019 04:46
07-01-2019 04:46
I'm having the same exact issue. Auto bright was working until yesterday
16:00
10:08
07-02-2019
16:00
10:08
It's great to see you around @fit-lou. Thanks for the details mentioned.
I would like you to confirm that you've restarted your Ionic and changed the brightness. To do so:
- Open the Settings app
- Tap brightness to adjust it
Let me know how it goes. I'll be around if you need further assistance.
