09-14-2020
17:20
14:47
SilviaFitbit
09-14-2020
17:20
14:47
SilviaFitbit
Hello,
I purchased a Fitbit Ionic: Adidas Edition approximately one year ago. Everything was working fantastic until about a month or so ago, or around 2 firmware updates ago. All of a sudden, instead of the usual 10%-20% drain per day, it started draining at a rate of about 25%-30% every 8 hours (75%-90% in a day). I can still keep it functioning by charging it before work, after work, and before bed. However, that is a bit frustrating, as it takes a good 30-45 minutes to recharge that 25%-30%. The battery drained 23% as I slept last night.
I have tried changing the clock face, as suggested, which is now frozen stuck in an infinite loop saying "the clock face could not be installed." (I attempted to install the top staff pick clock face - "Clean Cut" by John Boy Software). Since it is now stuck in a loop trying to install that clock face, I cannot attempt to switch to another.
I thought perhaps the battery was draining because the Ionic had lost its WIFI connection and was continuously searching for the network. When I attempt to open the WIFI settings, it repeatedly gives me the error "Something went wrong when attempting to open the WIFI settings." I completely disconnected the Ionic from the phone, reset the Ionic, and restarted the phone. I connected the Ionic back to the phone successfully (which requires it to connect to a WIFI network), but when I attempt to open the WIFI settings, I still get that same error.
Even after the reset and repairing, the battery continues to drain at a rate of about 25%-30% every 8 hours.
14:55
10:34
09-15-2020
14:55
10:34
@smstolz It's nice to see you in the Fitbit Community. Thanks for the detailed information shared and the troubleshooting tried prior to posting.
In this case, I've shared your post with our Support team and someone will contact you as soon as possible. Keep in mind that due to recent events affecting our operations we may take a bit longer to get back to you.
I'll be around if you have any additional questions.
Best Answer09-15-2020 15:16
09-15-2020 15:16
Hi Silvia,
Thank you. I will look for their email.
I did manage to change the clock face to the new SpO2 one that was released with the new firmware update. However, the battery continued to drain at the same rate.
09-18-2020 18:55
09-18-2020 18:55
I just installed the spO2 clock face a couple of days ago. I thought it was my fault for not fully charging, but is draining in 12 hours to zero and used to last 3-5 days. Help!!!!
Best Answer09-19-2020 01:15
09-19-2020 01:15
Things I would try in order, checking battery life before moving to the next suggestion.
1. Restart the Ionic.
2. Uninstall the SP02 clock..
3. Reset the device.
