10-02-2018 17:35
10-02-2018 17:35
10-03-2018 05:13
10-03-2018 05:13
Hi, @DannielleYgosse, for charging issues it is a good idea first to clean the contacts. Instructions here, then give your Ionic a restart.
After that charge your Ionic until it shows fully charged (using a UL / CE certified mobile phone charger should take no longer than 2 hours -- charging via a computer or laptop USB may take considerably longer, and don't forget that in most cases a computer will not deliver charge unless it is awake).
Once it is fully charged, monitor how long the battery lasts, preferably over several charge cycles. If it continues to die in such a short time, either post here again, or get in touch with Fitbit Customer Support on contact.fitbit.com. Be sure to tell them the troubleshooting steps you have already tried.
Best Answer10-03-2018 13:46
10-03-2018 13:46
Best Answer10-04-2018 08:15
10-04-2018 08:15
And me! started in the last couple of days.
