01-13-2018 10:01
01-13-2018 10:01
I had a Ioninc that wouldn't record my flights properly. Sent it in to Fitbit and they've replace my device with a new one. I received my replacement Ionic. I must admit my level of frustration now with this replacement as it is, is worse off than the previous one.
The Bluetooth doesn’t stay connected and is intermittent. I managed to get the Ionic setup with its initial firmware update and set it up with app. Seems fine....but
Then it wasn’t connecting to my iPhone 6s trying to sync the device. So I removed the device from the app and went to re add it. It gets to where I have to punch in the pairing number and then hangs forever on Connecting to Fitbit. I can force close the app and restart and go through the add device steps and again it hangs after I enter the pairing code.
I eventually did a factory reset on the Ionnic and got it all setup again. I left it for the night and got up this morning to sync it to see my sleep.
I noticed in the app the heart rate monitor was stopping and going intermittently and it was not syncing and my sleep was not being shown. Like the connection to the device was working then not and then after a few seconds it would kick in again but never really sync.
I removed the Fit app from my phone and re installed it. Still nothing, turned Bluetooth off and on again and notihng. So I removed the device to add it again from the App and again I am stuck at CONNECTING TO FITBIT just hanging there.
I do not want to factory reset this device because if I do it takes 2 hours to get it to download the firmware. On top of that the wifi feature doesn’t work and I have to firmware update through Bluetooth. Same as what I had to do with my old device. This is ridiculous!!!!
I am honestly pissed that I gave my Charge 2 and Flex 2 device up for this $400 piece of crap. I honestly thought Fitbit was better than this. I am in no way pleased with how this is turning out.
04-22-2018 12:05
04-22-2018 12:05
Best Answer04-22-2018 13:04
04-22-2018 13:04
So,
Could we have some form of update from Fitbit about this? I have a pretty useless piece of expensive junk that can't connect via it's only method of connecting......Bluetooth. It's even useless as a watch as it syncs time with your phone but loses time after days of not being able to sync, Useless!!!
04-22-2018 20:17
04-22-2018 20:17
I am having the exact same problem
04-22-2018 20:19
04-22-2018 20:19
I have lonic watch which I purchased a few months ago and installed the Fitbit app on my iPhone 6s phone it worked quite well until a week ago . I get Bluetooth connection issues and detection issues etc . I reset my watch etc has not resolved my issues ., would you advise me what to do next is it is not working
05-02-2018 06:15
05-02-2018 06:15
Same here.
It has been several weeks now that I can't get my Ionic to sync. Bluetooth hardly ever functions.
I'm unable as well to update to OS2, be it through bluetooth or wifi.
And yes Fitbit, I've tried all of your troubleshooting items at least once.
Don't seem to be the only one waiting for a clear explanation by Fitbit.....
05-05-2018 10:23
05-05-2018 10:23
Same Here. Great watch when it works. My Ionic will not receive notifications at all. It will sync, but that is all. Returned the first one and replacement performs the same. Spent hours working with Fitbit customer service without resolution, All I am told is that bluetooth bonding problems are a known issue and fitbit is working on it...... Any day now would be great. I will be returning this unit as well before expiration of the grace period if it is not resolved quickly. I am done with spending any more of my time in an attempt to get this unit to work. As I said I love the unit if it works.
05-08-2018 00:04
05-08-2018 00:04
Hi, I am experiencing the same problem with my surge and ionic. the bluetooth doesnt seem to work. tried to sync my data from my tracker to my mobile fitbit app but to no avail. any solutions?
05-08-2018 04:42
05-08-2018 04:42
Hi
there is no solution. It is not a bug(software issues) that causes problem. It is a fundemental design and implementation problem. It is the core design that has not been implemented properly . I gave my ionic watch back , got new one, but I still get connection issues thought not as bad as the previous one but still the issue is there. I believe Fitbit exposed its quality of its watches . The watch software does not integrate properly with the app. It is not a bug , it is an implementation problem .
05-08-2018 04:52
05-08-2018 04:52
Best Answer05-19-2018 05:05
05-19-2018 05:05
Keep having same issue works fine for a few days then looses conection and then is next to impossible to sync up again
Best Answer06-07-2018 18:53
06-07-2018 18:53
I used the link and no luck in getting my ionic to connect to my iPhone 8. I have removed the tracker from the app. Removed and reinstalled the app. Turn the tracker off and on. Rebooted the tracker. Factory reset the tracker. Restarted my phone. Removed all other Bluetooth devic s from my settings.
I cant get past the 4 digit verification.
06-14-2018 06:35
06-14-2018 06:35
Same here. Bluetooth connectivity is horrible, and has always been horrible for the 6 months I've owned this watch. Factory reset will work for a week or so, then the fun starts all over again. Ridiculous.
06-14-2018 07:01
06-14-2018 07:01
I'm having major issues with the Ionic. Its crashed my phone. It wont pair. Its tripled my steps. And it wont pair with my scale. I had the Charge 2 and had ZERO issues.
Best Answer06-15-2018 06:24
06-15-2018 06:24
Same issues here! Was fine until the latest update. Bluetooth isn’t working at all. I don’t mind syncing issues but it’s a pricey bit of kit!!
Best Answer06-23-2018 15:24
06-23-2018 15:24
Fitbit are finally sending me a replacement, why can’t they just see their is a problem
with this product. I had the Fitbit one.....no problems......then the Fitbit Surge no problems. This has been an awful product. Saying that though my partner has the ionic Adidas edition and that has had no issue.
Best Answer06-23-2018 16:37
06-23-2018 16:37
Best Answer06-24-2018 09:40
06-24-2018 09:40
I am having the same issue. Now I cant even change my clock face. Tried factory reset. Used my phone, a tablet and windows app. keep getting connection errors. Very frustrating because I want to like the product but it is full of bugs.
Best Answer06-24-2018 10:54
06-24-2018 10:54
I have that problem when I use Android smartphone or Win 10 App.
Of course the other BT connection is off!
If I use the Ionic only with Android I have no problems.
But only using Android app is not possible because music transfer is still not possible!
I hope Fitbit is going to improve the BT connection.
All my other BT devices are working without such connection problems!
Only Fitbit has these problems.
Looking forward for bugfixes!
Regards
Mark
Best Answer08-20-2018 09:36
08-20-2018 09:36
I just started reading this forum and now I'm glad it's not me. This all started after the last FW update. Has anyone gotten a solution from anyone? Thanks for the help...
Best Answer08-20-2018 09:51
08-20-2018 09:51
