06-27-2019 05:22
06-27-2019 05:22
My Ionic suddenly powered down and when I charged it full it was not synced with the hour, nor the IPhone, also not connecting to Bluetooth, so I read on the forums that a suggested solution would be to do an repairing, did it but after the PIN request it didn't connect, back again in the forums they suggested to do a factory reset, went for it, it paired and connected and started an update, with the Ionic hooked to a power source it started to download it, more than a half downloaded and it went black, checked the power source, everything fine I was thinking it needed time, but guess what? Nope, it didn't come back 😞
Any ideas to make a come back from the dead?
Best Answer06-28-2019 11:14
06-28-2019 11:14
A warm welcome to the Community @fcolomas. Thanks for the details mentioned. I appreciate the troubleshooting tried.
Thank you for the research done before posting. It's pretty weird that your display isn't working after you performed the factory reset. I would like you to try to restart it and make sure you're fully charging it.
If you get the display to work, then please set it up again to your account.
Let me know how it goes. I'll be around if you need further assistance.
Best Answer06-28-2019 11:30
06-28-2019 11:30
Best Answer06-29-2019 14:57 - edited 06-29-2019 14:58
Thanks for confirming the troubleshooting tried @fcolomas. Any other methods that I should try before completely lost my hope? I will be happy to help you. ![]()
Since, you've tried the recommended troubleshooting, I've shared your post with our Support team, they will continue assisting you.
I'll be around if you have any question!
