Hi, After update recently , my ionic is on dim and can not make it brighter as brightness and others are greyed out(there is a moon in the settings) . I see posts where people say to adjust the "sleep mode". I do not see anywhere to do this.
I tried to do a factory reset and now the screen is going through different languages and the message say "to start, download the fit bit app" which I already have.
Any help would be greatly appreciated, VERY frustrated with this watch.
Thanks for the response. Where exactly do I turn off the sleep mode? The only option that was available was the "Sleep sensitivity" Unfortunately, I did a factory reset and now the watch is just going through diffent start up languages. I have turned on and off the bluetooth on my phone and also restarted 5 times and still the same. I have erased and reinstalled the app now says found it, it has been connecting to the tracker for 1/2 hour. Tried this several times... Anyone have any ideas? Thanks!!!
Best AnswerSorry, not sure if you got it.
On the watch, swipe to the settings option, then scroll down to Sleep Mode
Best AnswerI am also experiencing this problem. Not all of my settings options are available to me. The Sleep Mode option is ALSO greyed out. I turn the watch on and off and nothing changes. Finally, on its own, it goes back to the bright setting but the Sleep Mode option remains greyed out.
Best AnswerExcellent! Thank you!
