@SuperStevo86 wrote:I've installed the Photograph clock face to my Ionic but I'm not able to open the background image picker in the Fitbit app for Windows 10 on Mobile. Please help.
I have installed the photograph too and used fitbit app on my phone to launch selected picture on my Ionic with no issue at all.
Steve
Best AnswerAre you using the Fitbit App for Windows 10 Mobile? If not, your reply does nothing to help me.
Best AnswerI'm using the Fitbit App for Windows 10 Mobile and I have the same problem. I can install the watchface but when I try to select a picture, I can only see the text
"Pick a Background Image
Background Image picker"
But I found no way to select a picture or to take a photo.
Regards,
Silverchair
Best AnswerSame here Windows 10 Mobile running on Lumia 950XL. Installed the clock face without incident but unable to browse the phones gallery/camera roll to pick an image.
Windows 10 Mobile build - 10.0.15254.369
Fitbit app version - 2.29
Best AnswerSame here. When going into settings, I just get a blank screen with the back arrow.
Windows 10 Mobile on HP X3 Elite phone.
Latest up to date version on all software...
Best AnswerHi @Zyxian
It's just a display problem: When you tap at the right edge of the field, you can select a picture.
Regards,
Silverchair
