02-08-2018
13:57
13:20
ErickFitbit
02-08-2018
13:57
13:20
ErickFitbit
Hi all!
I am super excited to announce the release of Fitbit OS 1.2! (Firmware Version: 27.31.1.29)
We've begun to roll out this new firmware to 10% of Ionic users. This is a progressive rollout, and all Ionic users can expect to have it within a few weeks. We roll out releases in phases as a cautionary measure so that we can monitor performance closely and make adjustments if needed. This firmware update includes:
Feature update:
What’s fixed:
Click here to view our Fitbit OS help article!
Instructions for updating your Ionic can be found here.
I would also recommend updating your Ionic over Wi-Fi as this can greatly reduce the time it can take to get set up. For more information on connecting your Ionic to Wi-Fi, check out this article.
If you run into any trouble updating your Ionic, I can also recommend reviewing these troubleshooting tips.
Looking forward to hearing everyone's feedback on the latest release. If you have any questions, feel free to let me know!
Want to get more deep sleep? Join the discussion on our Sleep better forum.
02-23-2018 13:58
02-23-2018 13:58
02-23-2018 14:02
02-23-2018 14:02
@MattFitbit- and this Firmware destroy the Bluetooth Connection for IONIC devices. Did FitBIT not tested his Firmware? See the Thread and you will see, that many other Users have the same Problem.
With the old Firmware and App-Version (Android) from December 2017, we didn't have anny issue. And now we have the Issue with the last App-Version or December 2017 Version, with this Firmware:
Hope, you will publish quick give me a Instruktion, how can i make a downgrade from the Firmware.
02-23-2018 14:10
02-23-2018 14:10
@TheAssimiator, the firmware update did not destroy the Bluetooth connection with my Ionic. It still syncs reliably with my Android phone any time I open the app. There are users that have reported syncing problems after the firmware upgrade, but there were also a number of users reporting problems with syncing before the upgrade.
02-23-2018 14:13
02-23-2018 14:13
Almost a week after Firmware Update, only once I got crush. (Previous version, never crush.)
And I hope HR accuracy will be improved, but it seems no change.
When Running, my Ionic HR shows 200bpm, but it seems way off. Treadmil shows only 130bpm.
When not excerise, HR seems OK, but when I run or excerise, right away, Ionic HR shows over 150bpm and I cannnot rely on Ionic HR Measurement...
GPS seems working OK for outside running so far.
I hope Fitbit will improve HR Accuracy drastically.... Now, I cannot rely Ionic Measurement for HR...
02-23-2018 15:14
02-23-2018 15:14
Right I have managed to get the time sorted and my watch is syncing after a fashion but it will not allow me to establish a WiFi connection.
This update is definitely a step backwards in my experience.
02-23-2018 16:15
02-23-2018 16:15
Fitbit did it to me again! Against better judgment I updated with the release. I' having constant trouble syncing now. I've restartef, logged out/in etc. What's being done, I'm sure it' not just me? And any suggestions to fix it??
02-23-2018 16:18
02-23-2018 16:18
Mine has been working perfectly fine since I got it. Seems Apple is your issue as I am running Android on my Moto Z2 and it has been flawless.
02-23-2018 16:20
02-23-2018 16:20
It took me around 20 mins
02-23-2018 16:26
02-23-2018 16:26
Time to get a notebook, count your steps manually, and buy a Garmin. No one is ever happy with anything.
02-23-2018 17:47 - edited 02-23-2018 17:47
@Scoobz7wrote:Time to get a notebook, count your steps manually, and buy a Garmin. No one is ever happy with anything.
Or you mean manufacturers keep making promises they can’t keep?
02-23-2018 18:41
02-23-2018 18:41
Hi, received the firmware update, but now, when I turn my wrist to look at the time, nothing happens! The watch doesn't respond to opening the screen. Instead, I have to click one of the buttons to turn it on. Is this a bug? How can I fix it? Please help!
02-23-2018 18:50
02-23-2018 18:50
@leeshiela, have you checked the setting on the Ionic setting for Screen Wake (the screen left of the Clock screen) did not get changed from Auto to Manual?
02-23-2018 18:51
02-23-2018 18:51
Hi @leeshieladid you check your settings? Maybe the update changed it back to manual? @Scoobz7 I don't think any of us enjoy coming here with problems. I'd be thrilled if the ionic worked as advertised and if fitbit didn't keep releasing products and updates that waste my time and money. If the ionic just worked I'd be the first to write an awesome review and never need to write on the boards again. I don't do much social media and would absolutely prefer to spend my time doing something else.
02-23-2018 18:55
02-23-2018 18:55
@MattFitbit I've tried setting it manually as well as setting it to automatic. It seems to count my steps correctly when walking slowly and exaggerating my arm movements. When running, it only counts about 80% of my steps. Considering I bought this for running, it's not doing me much good. Any other suggestions? I've already been through the factory reset process.
02-23-2018
19:02
13:32
MattFitbit
02-23-2018
19:02
13:32
MattFitbit
Swipe right on clock face and set Screen Wake to On.
Moderator edit: removed personal info
02-23-2018 19:13
02-23-2018 19:13
Yes, that worked! whoops!! Thank you!!
02-23-2018 20:09
02-23-2018 20:09
@MattFitbit That is a lot of answers in a single post. As for your comment with my issue specifically. I have never understood why Fitbit support has suggested changing stride length for missing steps. The stride length is just used to multiply against the steps to determine distance not number of steps. It doesn't change how sensitive the devices is or make it suddenly count more so why does the support suggest it?
02-23-2018 21:29
02-23-2018 21:29
02-23-2018 21:54
02-23-2018 21:54
@Scoobz7wrote:Mine has been working perfectly fine since I got it. Seems Apple is your issue as I am running Android on my Moto Z2 and it has been flawless.
It’s not Apple. I’ve got an iPhone6 and no problems syncing ever. Unless my pc’s Bluetooth is connected, but using either one or the other no problems syncing with Windows 10 or Apple IPhone.
02-23-2018 22:51
02-23-2018 22:51
I'm on Android
