10-15-2020
23:30
16:48
SilviaFitbit
10-15-2020
23:30
16:48
SilviaFitbit
My heartbeat sensor keeps stopping working, usually right in the middle of cardio when im wanting to use it the most.. very frustrating to say the least.
I've tried a reset and I've also made sure its turned on from the settings on the fitbit itself.
and also syncing it when its not working to see if that brings it to life.
it usually comes back on eventually on its own but it could be hours before than happens.
anyone else having the same problem? may have to get a garmine if this continues......
16:43
13:52
10-16-2020
16:43
13:52
@RyanCOR A warm welcome to the Fitbit Community. Thank you for getting in touch about this.
I appreciate the troubleshooting tried prior to posting. I see where your frustration is coming from, let's work together to sort this out.
In this case, I'd like you to confirm you're following these tips to ensure your Ionic is properly worn:
Also you may want to check these factors that can affect your heart rate reading on your Fitbit device.
Let me know how it goes.
17:52
13:50
10-17-2020
17:52
13:50
@RyanCOR Thank you for getting back. I totally understand your disappointment with this as you're using it for everything.
In this case, I've shared your post with our Support team and someone will contact you as soon as possible. Keep in mind that due to recent events affecting our operations we may take a bit longer to get back to you.
Have a nice weekend!
Best AnswerFitbit ionic just plain isn’t working. I have rebooted, reset...nothing works. Please fix you update that screwed it up. Or give all of us ionic users your newest Fitbit. It is your problem, you caused it
14:12
13:48
10-21-2020
14:12
13:48
@Shoshe Hi there. Thank you for getting in touch about this.
I appreciate the troubleshooting tried prior to posting, I see where your disappointment is coming from. In this case, I've shared your post with our Support team and someone will contact you as soon as possible. Keep in mind that due to recent events affecting our operations we may take a bit longer to get back to you.
Have a nice week.
