02-01-2019 03:32
02-01-2019 03:32
Can't find the full Ionic manual and also how do I turn bluetooth on/off? Thanks...
Best Answer02-01-2019 03:33
02-01-2019 03:33
The manual is at: https://staticcs.fitbit.com/content/assets/help/manuals/manual_ionic_en_US.pdf
You can't turn bluetooth on / off on the ionic - it's permanently on.
02-01-2019 03:38
02-01-2019 03:38
Appreciate the response!
Best Answer02-01-2019 04:50
02-01-2019 04:50
It told me my bluetooth was off...
Best Answer02-01-2019 04:51
02-01-2019 04:51
Perhaps it meant your phone?
Are you having a problem with your fitbit?
02-01-2019
05:49
09:41
SilviaFitbit
02-01-2019
05:49
09:41
SilviaFitbit
Was told that bluetooth is always on in the ionic...mine tells me bluetooth is off! Is there a way to turn it on/off?
Best Answer02-01-2019 07:43
02-01-2019 07:43
In the fitbit app is where it said the bluetooth was off...
Best Answer02-01-2019 17:55
02-01-2019 17:55
First let me welcome you to the community @rjrubin.
As for Bluetooth your Ionic has 2 versions, Classic and Low Energy.
Classic is the original and only used for connecting a speaker or headphone to your Ionic
Bluetooth Low Energy is the type of Bluetooth that the ionic and all fitbits use to sync the data.
It is the Classic Bluetooth that can be turned off. The low energy Bluetooth is normally listening for commands.
02-01-2019 19:12
02-01-2019 19:12
When I click on the ionic watch and then click on clocks, apps or fitbit wallet I get a message to make sure bluetooth is on. That's all it will let me do (click OK)...
How does this relate to my problem?
Thanks...
BTW: I sync fine...
Best Answer02-02-2019 12:24
02-02-2019 12:24
This would probably be referring to the phones Bluetooth, basically it is saying that the app is having problems communicating with the tracker.
For me this message usually disapears shortly, once the app makes connection with the tracker.
Yes I have noticed the tracker will sync so I'm assuming this connection is through a port(doorway).
I can only goes at what to try.
Restart tracker, restart phone, clear the phones cache are a few things to try.
Best Answer02-02-2019 13:05
02-02-2019 13:05
I sync with the dongle. Please re-read my previous reply and tell me how this relates to my phone???
Best Answer02-02-2019 14:10 - edited 02-02-2019 14:15
I'm not sure what you mean, are you saying that you do not have the Fitbit app on your phone? If using a dongle, is it the Fitbit Dongle? A generic one should not work properly.
So what device is it that you get this error on?
If the ionic is currently connected to your phone, this could be the problem of you receive the error on a computer?
Do you sync through a win 10 computer or a Mac a computer?
I did reread and all I found is a reference to the Fitbit app of which there is 4 versions.
I also merged your two threads that are on the same problem
Best Answer02-02-2019 17:30 - edited 02-02-2019 17:32
sorry...I sync through my desktop running Windows 10...I don't even own a smart phone. And yes, it is a fitbit dongle...
