01-12-2020
17:32
14:40
RicardoFitbit
01-12-2020
17:32
14:40
RicardoFitbit
Can both be connected to same account, to interchange seamlessly. It sucks having to set up the device each time I want to change
01-12-2020 18:05
01-12-2020 18:05
Unfortunately, I think you already know the answer. Quoting from
Can I use more than one Fitbit device with the same account?
Note that you can't connect multiple devices that use the Fitbit App Gallery to one account. For Fitbit Charge 3, Fitbit Ionic, Fitbit Inspire series, and Fitbit Versa series, only connect one of these devices to your account at a time.
01-12-2020 18:05
01-12-2020 18:05
07-16-2020 20:48
07-16-2020 20:48
This needs to be a soon coming change to configuration on the Product Roadmap. I enjoy being able to switch between my Ionic and Surge with no issues - seamless. This is my fourth Fitbit model and I bought it specifically because it works with the clip so that I can wear a nice watch to events and not have a fitness tracker on my other wrist. This is one of the uses that's promoted so if this is a limitation the limitation should also be called out in ALL product descriptions when you are also talking about using it in that way.
