09-14-2020
20:41
18:10
SilviaFitbit
09-14-2020
20:41
18:10
SilviaFitbit
So last two weeks my ionics battery life is going down hill it started at 5 days and now it’s anywhere from between 2-3 days. And it’ll be at 50% at 3 pm and by 10 pm it’s completely dead. Idk if there’s a setting I have that’s draining it or what but this is aggravating.
GPS is about the only battery draining function. If no GPS running function, then likely the battery is ageing, or the latest fw has/is causing issues. Worth doing a restart - Shutdown/restart. I don't believe a factory reset will help. But stranger things have happened. Best to read the latest fw thread before doing a factory reset though. Some have killed their Ionic by doing a reset - as incredulous as this is.
Best AnswerI've noticed I have put the new Sp02 watch face on my ionic and that's when the battery draining started for me. I've removed that watch face and will see how it goes.
I’ll give it a shot too. See if it helps. I wonder though if the new update has something to do with it.
Best AnswerHow do u do a shutdown / restart. Is it the same as just going into settings and turning it off. ?
Best AnswerHow can I switch off GPS? And where can I see if GPS is running?
Or is it always on and not possible to switch off?
I have tried factory reset, but nothing helps. Have to charge every other day.
