10-13-2020 12:42
10-13-2020 12:42
I used to get 4-5 days. Since 9/15 I'm only getting 2 days. What can be done?
Best Answer10-13-2020 12:49
10-13-2020 12:49
I've found the Sp02 watch face has drained my battery.
Best Answer10-13-2020 14:16
10-13-2020 14:16
I'm using the default watch face. I'd like to use the SpO2, but don't want to make it worse.
Best Answer10-13-2020 14:40
10-13-2020 14:40
Try it. The Sp02 face is usually run over night and then in the morning after a data sync the face should be changed back to your default/preferred. I haven't noticed any appreciable battery draining from running the Sp02 face over night. I'm sure this can vary between users though.
Running a GPS function on the device is a battery killer. When I go for a GPS assisted bike ride the battery can deplete 40-50% in around a couple of hours.
Best Answer10-14-2020 03:49
10-14-2020 03:49
Did you upgrade the firmware? I did, and I have the same issue ever since and the whorst is there’s nothing you can do about it. I did the factory reset and all nothing seems to help. Contact the support. If it’s not older than a year they probably change it for you.
