03-10-2020 06:29
03-10-2020 06:29
Why does my Ionic disappear from my computers and cell phone? Sometimes I turn my computer on and can't get steps or sleep displayed? When I click the upper right corner symbol to display features often the Ionic is not listed. I have to SET UP A DEVICE again to get it back. I have similar difficulties with my cell phone.
Best Answer03-11-2020 10:45
03-11-2020 10:45
@ok1wire It's nice to see you on the Community. Thanks for the detailed information shared.
I appreciate that you got in touch about this. It's pretty weird that your Ionic is disappearing from your account and you need to set it up again.
I would like you to make sure you're logging into the same account every time you're logging into your app or online Dashboard. This could be the reason why your Ionic keeps disappearing from your account. I've noticed that this usually happens when you have two email addresses that are similar, so you could log into your app or Dashboard using a different one.
I'll be around if you have any additional questions.
Best Answer03-12-2020 02:57
03-12-2020 02:57
Best Answer03-13-2020 14:38
03-13-2020 14:38
@ok1wire Thanks for getting back. Now you could say that somehow Fitbit is helping you to sleep when you wake up in the middle of the night. 😅
In this case, I've shared your post to our Support team and they will continue assisting you through email, they will continue assisting you with your Ionic disappearing from your account.
Regarding the syncing issues that you experience, a low internet signal could cause syncing issues. As you mentioned, it syncs faster with your cellular data on your phone. Learn more about it by checking this article: How do Fitbit devices sync their data?
In regards to the sleep score showing on your Fitbit app, this is available only through the Fitbit app and not through the computer. If you would like that this could be available on the computer, you may want to post your idea in our Feature Suggestion board, those ideas are reviewed by our team and the status will change based in Fitbit's plans.
