07-07-2020
07:38
17:53
SilviaFitbit
07-07-2020
07:38
17:53
SilviaFitbit
ionic worked well. but suddenly auto brightness stop working. then after few days once in the morning display not working. I could only see back light. I tried some time but noting happened. after few days I tried again. and it started. but the next day same problem. it restart continuously and display appear and gone. after that only back light appear. I can feel resets options both 2 buttons and 3 buttons. can find my fitbit with my phone. but cannot connect without the CODE appear on screen. What happened with my watch and how can I solved it? After the last update it happened.
Thanks.
17:50
08:20
07-08-2020
17:50
08:20
@suraj_2020 A warm welcome to the Community. Thanks for getting in touch about this.
I appreciate the detailed information shared. Since your display isn't working and you're unable to set your Ionic, please try restarting it and check if the display works after this.
Let me know the outcome. I'll be around if you have any additional questions.
Best Answer07-08-2020 23:17
07-08-2020 23:17
