Hi all,
My Fitbit Ionic does not synchronize properly anymore. After a few hours the time is set back 10 minutes from the reality. Only until I put it on the charger it synchronizes again. Does anyone have a solution for this problem. I have a watch that does not give the right time 🙂
Thank you.
Hi @RobertK90, welcome to the Community Forums. I'll be more than glad to give you a hand with this.
Once your Fitbit starts syncing again, it will keep the correct time on the screen. I'd like to confirm what model of phone you're using. I'd recommend to check some requirements that your phone and Ionic should have in order to successfully communicate:
Requirements:
If the syncing issue remains with a mobile device I would recommend following the steps below:
In case of having an Android phone, also check your phone Permissions and leave location on to keep syncing and getting notifications with your phone, for more info check this suggestions from @ErickFitbit. ![]()
I'll be around in case that you need more assistance.
Requirements:
