04-30-2018 01:53
04-30-2018 01:53
Ok. My new Ionic does not seem to want to charge. The screen is flashing the battery icon with 0% - I can't seem to do a reboot by pressing left button with bottom right button. Stuck
Any suggestions?
Best Answer04-30-2018 02:22
04-30-2018 02:22
@Stripey I would say to contact Fitbit support if you have had it on charge for a while and nothing is happening. I have found them.to be most helpful in resolving issues.
Try the link below.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
Best Answer05-01-2018 01:51
05-01-2018 01:51
Best Answer05-04-2018 14:38
05-04-2018 14:38
@StripeyNo worries, sounds promising.
Tony | UK
