05-14-2020
07:34
10:44
SilviaFitbit
05-14-2020
07:34
10:44
SilviaFitbit
I just bought Fitbit Ionic 2 weeks ago. The Bluetooth was always auto disconnected and unable to see the incoming WhatsApp from the watch. Is anyone facing the same issue?
Best Answer05-15-2020 10:50
05-15-2020 10:50
@Pretty-Ling A warm welcome to the Community. Thanks for getting in touch about this.
I would like you to confirm that your phone operating system is compatible with the Fitbit app:
Please confirm you did this procedure to set your notifications. Also, reply to the following questions:
- Which mobile phone do you have?
- Is your Bluetooth always on?
Looking forward to hearing back from you.
Best Answer05-16-2020 00:13
05-16-2020 00:13
Hi! Event is bot my post but i have the same problem. I can't her notifications on my watch. I checked bluetooth conection and that I have switch saving battery options... I have my fitbit couple of years... It was on the beginning but after some systems updates that change... I used fitbit with few different phones just to check if is not a phone problem... With every phone is the same... Now I have new Xaomi Redmi Not 8 pro since 2 days and is again the same problem...
