11-03-2017 05:39
11-03-2017 05:39
Since installing a different clock face on my Ionic, it is intermittently resetting. It vibrates and when I look at the face, it is displaying the Fitbit logo then returns back to normal. It will sometimes reset whilst working out and am not sure whether it is still recording my workout or steps. Anyone else having this issue? I've only had the Ionic for about three weeks and am pleased with it in all other respects.
11-03-2017 06:11 - edited 11-03-2017 06:12
Your specs please?
Seeing forum posts here from my perspective it appears that clock faces are buggy. I wouldn't bother with them until the next firmware upgrade.
Best Answer11-03-2017 06:28
11-03-2017 06:28
Try changing the clock face to a different one, and then back to the one you want (this helped me when I faced this with the cinemagraph face).
Also, in case you haven't, you can try resetting the ionic, by pressing the left and bottom buttons, until you see the logo.
Best Answer11-03-2017 08:50
11-03-2017 08:50
I'll give the reset a go... thanks 🙂
Best Answer11-03-2017 08:51
11-03-2017 08:51
Thanks FitAlexS. I won't bother changing the clock faces until the software is a bit more stable 😉
11-03-2017 12:24
11-03-2017 12:24
This has started happening to my fitbit this week, however i have not made any changes or even used any of the features, just been wearing it as a normal watch
