I got my Fitbit ionic a month and a half ago second hand and it worked fine until a week and a half ago where it started to have trouble syncing. Roll onto now where it's refusing to syncrsynchr to my phone unless I log out of the app, and reset my Bluetooth. I love the watch but I didn't pay £100 + for a non working fitness tracker
This watch was bought from CEX
I would like a full explanation of why this is happening and how it can be resolved.
I have factory reset my watch, I have reinstalled the app I have reset my Bluetooth. Unpaired the watch and a few more. None of this has worked
Best AnswerMine was synching fine yesterday. Last night I went to synch and I havent been able to get it to synch since. Not sure what is going on. It did this one other time too. It finally was able to synch after a day or so the last time.
@OllyHiggs @JacqueH, I would suggest you both try rebooting your Ionics by holding the left and bottom right buttons at the same time until you see the Fitbit emblem appears and retry syncing after the reboot. If this fails the next stage would be to clear the fitbit App cache in your phone's settings. Hopefully one of these steps will help you.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
you can try to get help from the chat, or you could just stick pins in your eyes, same result. These people are as worthless as the watch. Just take a sharpie and draw a square on your wrist! works just as good as the watch!
@OllyHiggs I would suggest contacting Fitbit support I have found them to be helpful in resolving issues I have had in the past.
Tony | UK
Best AnswerI used my boyfriends phone to see if I could log in and synch using a different device and it went with no problem. If you have the option to try using a different device. Now on my device it is working just fine again.
@OllyHiggs you need to contact Fitbit Support and get a case logged. If you click on the blue text above it will take you directly to the contact page.
Tony | UK
@JacqueH Well if your Ionic syncs on your BF's phone your Ionic is fine. Did you try clearing the Fitbit App cache in your phone's settings to see if you could sync it?
Tony | UK
