08-12-2019 16:21
08-12-2019 16:21
My Ionic has all of a sudden stopped vibrating for alerts such as alarm and countdown....tried eveything:
Restart
Forget device & Re-install
Full factory reset
and nothing......any ideas!?
Best Answer08-12-2019 17:40
08-12-2019 17:40
@RobP1978, check out this post, to see if it provides any help with your problem:
https://community.fitbit.com/t5/Ionic/Ionic-won-t-vibrate/m-p/2817211
Best Answer08-12-2019 17:42
08-12-2019 17:42
Hi @RobP1978, welcome to the community.
Have you tried going into the settings app on your Ionic and scrolling down to vibrations. Try toggling between the options (normal and strong) to see if that fixes things?
If not, it could quite possibly be a hardware issue as you did mention doing a factory reset (which would pretty much rule out any software issues).
Best Answer08-13-2019 03:51
08-13-2019 03:51
Tried everything
deleting app
restarting watch
factory reset
bluetooth and WiFi on off
looks like it’s time for a Garmin....
