10-16-2019
09:23
14:27
SilviaFitbit
10-16-2019
09:23
14:27
SilviaFitbit
I bought a bew fit bit ionic not even a year ago and have had nithing but charging issues now it will not even charge or reset. Very disappointed any ideas? I have teied resetting which it will not do know and new charger. The thing is dead and I'm thinking maybe getting another product instead of fit bit
Best Answer10-16-2019 11:15
10-16-2019 11:15
10-16-2019 20:58 - edited 10-17-2019 19:07
Hi @Rpiercy Sorry you're having problems. Since you're under warranty, have you reached out to support? Fitbit does care and you should give them a chance to work with you on solving your issues.
10-17-2019 10:05
10-17-2019 10:05
Hello @Rpiercy, welcome to the Fitbit Community forums.
Thank you for all this information about your Ionic that is not responding and confirming that you already tried to restart to re charge the device. I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon.
Thank you for taking the time to share your feedback about the product as well.
Keep me posted on the outcome.
10-17-2019 17:21
10-22-2019 14:44
