06-16-2021 13:42 - last edited on 06-17-2021 12:44 by LiliyaFitbit
Can anyone help me , my ionic watch will not charge, it was working perfectly till a few days ago. Is there anything people can advise to do to fix the problem
06-16-2021 15:25
06-16-2021 15:25
Hi Lfc. Had the same problem with mine. I tried everything I was advised but nothing helped. Try cleaning your charging port there is usually debris in and around the terminal i used a tooth pick but didn't make a difference Try a hard reset back to factory settings that also never worked for me. I gave up in the end until someone from fitbit advised me to ring fitbit there will be people in there that may help. In the end my fitbit was done they offered me a discount off a new one or a replacement pebble which I was happy with. Hope you get it resolved
06-17-2021 13:55
06-17-2021 13:55
Welcome to the Fitbit Community, @Lfcdev23. It’s good to see you in the community, @GAWA99.
@Lfcdev23 Thanks for the details shared in your post. I appreciate your efforts and recommend following our troubleshooting tips in Why isn't my Fitbit device's battery charging?
@GAWA99 I appreciate your participation in the Forums and sharing your experience. Thank you for your time and efforts to help other users.
Hope this helps.
06-26-2021 13:26
06-26-2021 13:26
06-27-2021 18:26
06-27-2021 18:26
Thank you for your reply, @Lfcdev23.
I am sorry to hear the issue persists, thank you for your efforts. I recommend getting in touch with our Support team so they can look deeper into the issue and help you with this matter. Click here to get connected with them via chat or phone.
See you around.
06-27-2021 19:10
06-27-2021 19:10
deja tu reloj en tu mano unas 10 horas, con el movimiento de la mano, como que se activa y luego lo cargas y se inicia la carga
06-27-2021 19:14
06-27-2021 19:14
usa tu reloj así apagado en tu muñeca por unas 10 horas, luego intenta cargarlo nuevamente, y se inicia la carga, así lo hice y me funcionó
06-28-2021 12:32
06-28-2021 12:32
Welcome to the Fitbit Community, @gustavobetancur.
I appreciate your participation in the Forums and sharing your suggestions. Thank you for your time and efforts to help other users. Let me invite you to visit our Health & Wellness board where you can share your experiences, make new friends and create your own topics.
Keep on visiting the forums!
