08-22-2018
13:08
07:49
08-22-2018
13:08
07:49
Hi there,
My Fitbit Ionic stopped counting my steps yesterday. My Fitbit says 0 steps, my phone however is showing my activity. I have tried restarting my Fitbit, it is still doing the same thing. Anyone else having this problem? How do I fix this? All I see on the forum is a problem with the phone syncing, not the other way around.
08-23-2018 07:44
08-23-2018 07:44
Welcome on board @Myredgumball, it's nice to see you here! Thanks for already restarting your Ionic in order to solve this issue with your steps.
If your data is being showed up on your Fitbit app, I think that maybe the currently clock face is the inconvenience. Which one are you using? Can you try changing it to see if that solves this?
Fitbit Ionic offers several designs for the clock screen. To see your options, open the Fitbit app and tap or click the Account icon > your device image > Clock Faces > Pick a New Clock.
I've moved your post to the Ionic board as there are more chances to get related replies here.
Give this a go and let me know the outcome! ![]()
08-24-2018 09:42
08-24-2018 09:42
My Ionic is not showing steps, I put it in rice thinking it was wet from sweat, but still not does show. My iPhone does pick up the steps. Please help. I have turned off the Ionic and the iPhone without it helping and changed the face of the clock.
Best Answer08-24-2018 09:52
08-24-2018 09:52
Hey there @Reneejf, thanks for jumping in here! Since it seems you've exhausted all the steps in order to fix this, I'd recommend doing the Factory Reset on your Ionic. Note that you’ll need to reinstall any apps and music on your device after the reset, and since you haven't synced your device, then any data on the Fitbit device will be lost.
On your watch, open the Settings app > About > Factory Reset.
When the watch successfully resets, use the normal out of the box process of updating the firmware or you can see How do I update my Fitbit device? article.
Hope this helps, keep me posted!
Best Answer10-15-2018 12:48
10-15-2018 12:48
Yes, what is the answer?
Best Answer12-04-2018 11:13
12-04-2018 11:13
Switched from Big Weather to Stats. Watch face rest within 20 seconds. Thank you.
12-09-2018 06:54
12-09-2018 06:54
I had this problem. Switching the clock faces worked.
12-10-2018 11:13
12-10-2018 11:13
Welcome on board @Fivemillperyr and @Klk.4194! I'm glad to hear that you're steps are back on the display after switching to a different clock faces. ![]()
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Best Answer12-11-2018 03:31
12-11-2018 03:31
