02-15-2018
07:19
06:17
02-15-2018
07:19
06:17
I've read several other posts as my ionic was not synching to my phone, and had even caused the clock time to become off. I followed previous steps of disconnecting the ionic from my phones Bluetooth and removing the device to reinstall it. I continue to get stuck on the screen where it asks to enter a number which I receive on my ionic watch. After entering the number it just clocks and goes no where. I have also tried holding the left and bottom right buttons doing a restart, as well as going into the settings on the watch and doing a shut down and continue to get stuck after entering the number which was sent to my watch.
Hey there @sara_devoto, it's nice to see you around. Welcome! Thanks for already troubleshooting this issue, nice way to go!
While reading the steps you've attempted, I was wondering if you removed the tracker from your account only? If so, please go to the Bluetooth settings on your phone and remove the tracker from there as well.
Once you've made sure about that, go back to the Fitbit app, go to the "Account" option in the upper right corner and select "Set up a Device". This should start the setup process for your device. ![]()
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below:
If you're still unable to set up, try these troubleshooting steps:
Give this a shot and let me know how it goes!
Best AnswerI tried this and couldn’t get it to work. I then tried a factory reset and then it was able to pair and get past the 4 number verification screen.
I have the same issue that Sara described. I even tried syncing with another device, no help. I have tried everything except the factory reset on the watch. Is that the only solution? It would delete all data on my watch, which wasn't uploaded, which would really be unfavorable.
I have the same problem. My fitbit app was not updating from my ionic anymore. I disconnected from bluetooth, restarted both devices. Then I turned bluetooth back on, added a new device on the fitbit app, and my iphone screen is now stuck on the code i typed in, saying connecting to fitbit and stuck there forever. And yes, all my iphone software is up to date. And yes, I had removed first the ionic from the fitbit app. It has always been difficult to get it to sync, but this is now a problem since I cannot reconnect the ionic to the fitbit at all. Could you help me, please?
I have the exact same problem with my Ionic. All description above are exactly what I am encountering at the moment. Even going as far as factory-reset my own phone, but no hope so far. I suspect that the software requires access to Fibit server to check for update at the beginning of connection but seems like it is blocked. There is no better explanation why we all experience the same problem at the same time like this.
I finally got it to work by going back to a factory reset. I had tried everything else, following all the instructions on the 'device not syncing' topic. When I finally got it to work, I realized the syncing had stopped on the 7th April, which I had not noticed because I don't always check the fitbit app on my iphone. I was also disappointed with the fitbit support. I had to send a message through Twitter (it offered access through a live chat in the past) and it took until the next day for them to answer me. And it incensed me when they said in their message: "You can also try these syncing troubleshoots as well: http://help.fitbit.com/articles/en_US/Help_article/1866 …. If you have other questions, let us know." Seriously, Fitbit? Had you actually read the list of steps I took to resolve the issue, you would have noticed they were exactly the ones described in the article.
Thanks Everyone! I did factory reset my watch and it did sync with my phone. The problem I am encountering now is that when going into the app and trying to sync, it doesn't sync all the way. Partial data is collected (steps, stairs, etc.) no workouts, or 250 step hourly data is collected. The watch keeps trying to collect the data but doesn't go all the way (keeps resetting the sync).
At least the bluetooth works again...
At least when factory-reset, your bluetooth works. Mine is dead. This is a part from second email sent to Fitbit support team. I listed out all steps I have done so they might not ask me to repeat:
This is what i did to get it finally sync after a couple hours of trying different steps.
Best AnswerSo how is it that I click on an "accepted solution" for Broken After Ionic Factory Reset, I got stuck on 4 digit code? Seriously?!!!? After the factory rest my Ionic will only flash the fitbit logo. I have pushed, held, tapped, multi-tapped and pushed. I'm ready to just stomp this Ionic into dust and go back to my Apple Watch. Not happy, not happy at all. If you have a real answer I would love to hear it.
Best AnswerMy solutions that actually worked:
(1) Turn off your phone wifi.( it might be the root cause I do believe)
(2) Remove any setup within the app.
(3) Setup your fitbit with the app again.
Hopefully it will work. I encounter the same problem again this month but I figured it out somehow this way.
Best AnswerOh I forgot to mention that you should turn off any other devices' bluetooth. (PC, speakers etc...) . Please try and give us more feedbacks.
Best AnswerIn this case try a manually factory reset one more time, to do so you need to press and hold down all 3 buttons for 12 seconds. Then, release the lower right button only but keep pressing the other two buttons for 8 seconds.
Best AnswerDriving me mad. Every time they do a software update it stops syncing. Mine says “found ” then connecting to tracker then goes round and round for hours . Beginning to think this product is crap !!!
