If it's not syncing to multiple devices then it's likely to be a problem on the fitbit so I would suggest restarting it using this procedure: Help article: How do I restart my tracker?
It does no harm and can sort out all sorts of issues.
Best AnswerWhatever you do don’t try to do a factory reset it will go into the logo cycle of doom and Fitbit will tell you 🤷🏼:male_sign:🤷🏼:male_sign:🤷🏼:male_sign:
