08-10-2020
11:03
18:35
RicardoFitbit
08-10-2020
11:03
18:35
RicardoFitbit
My Fitbit ionic stopped counting steps. I’ve restarted it and charged it multiple times, but nothing works. Any ideas on how to resolve this? Thanks
08-10-2020 18:35
08-10-2020 18:35
Hi @DavidGA, welcome to the Community Forums!
Thanks for bringing this to our attention and for trying some troubleshooting steps before posting over here. Because our restart process didn't fix the issue, can you please try changing your device's clock face? If this doesn't work, please try our factory reset following the next steps:
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
I'll be here if further assistance is needed.
08-10-2020 18:35
08-10-2020 18:35
08-11-2020 14:33
08-11-2020 14:33
Thanks for your helpful reply. So far your recommendation is working, although I’ve had some previous “fixes” work for a few hours and then stop. Hopefully this will do the trick.
08-11-2020 15:02
08-11-2020 15:02
You're welcome @DavidGA, your update is appreciated.
I'm happy to know that the steps from my previous post solved your issue. Please do not hesitate to contact me back if you require further assistance in the future or if you have any additional questions for me to answer, I'll be here ready to help you out.
Thanks for being part of the Fitbit family, it was a pleasure to assist you.
08-11-2020 17:04
08-11-2020 17:04
Unfortunately, it’s already stopped counting steps again.
Any further suggestions?
08-11-2020 18:19
08-11-2020 18:19
Thanks for your update @DavidGA.
I'm sorry to know that you're still experiencing difficulties with your Ionic. Let me share with you that our Customer Support team was contacted on your behalf to provide you further assistance with the difficulties you're currently experiencing. Please keep an eye on your email inbox because they'll be in touch with you pretty soon.
In the meantime they contact you, let me know if you have any additional questions.
08-13-2020
14:29
19:11
RicardoFitbit
08-13-2020
14:29
19:11
RicardoFitbit
DavidGA,
Thank you for your suggestions to my Iconic Watch ( actually it is a Versa ) problem. Simply changing the clock face solved everything.
Christine
Moderator Edit: Personal info removed
08-14-2020 19:10
08-14-2020 19:10
Hi @Krispin211, welcome aboard.
I'm happy to know that after changing the clock face of your Versa the issue was resolved. Please do not hesitate to contact me back if you require further assistance in the future or if you have any additional questions for me to answer, I'll be here ready to help you out.
Thanks for being part of the Fitbit family.
08-16-2020 16:29
08-16-2020 16:29
my Fitbit iconic will not register my steps. I have already changed the clock face twice and I did the system reset which was suggested in this post and it's still not counting my steps. what do I do?
09-22-2020 08:00
09-22-2020 08:00
same issue, been in contact with support twice. The factory reset both times. Both times a short step track seems to work. Any long run or walk and while the GPS tracks the run ( I can see it on the map ) the KM's and steps are completely borked. A known 5K run is now showing between .8 and 2K random like.
08-20-2021 07:08 - last edited on 08-20-2021 13:53 by LiliyaFitbit
Hi
My Ionic is not counting steps. I worked out this morning for 4 1/2 miles and have 2451 steps.
i reset it, changed my clock and did the factory reboot and still not working.
any suggestions on what I do next?
Thanks,
5morganpk
08-20-2021 13:57
08-20-2021 13:57
It’s good to see you in the community, @5morganpk.
Thanks for the details shared in your post and for already trying to resolve the issue. I recommend confirming the following are correct in the Fitbit app:
Hope this helps.
