06-08-2019 13:59
06-08-2019 13:59
Hi,
This has probably answered previously but my ionic data is stuck on yesterday's data. Time and date are correct, data is from when it stopped yesterday.
I have tried pressing the two buttons (left hand and bottom right) to reset it three times, I have tried to go into settings, about, power off and done that twice. I have tried to change my watch face. Nothing is working. Does it mean it's finally decided to die on me?
Best Answer06-08-2019 14:36
06-08-2019 14:36
hi
i'm not an expert on this but have you seen the data on your phone? i think it may sync with the data of the phone where the app is !
i hope it can help you
Best Answer06-11-2019 01:23
06-11-2019 01:23
Hi,
I am having the same problem with my Ionic. Just wonder if you have found the solution ?
YFS
Best Answer06-11-2019 03:15
06-11-2019 03:15
I am also having the same issue. I have reset using the two side buttons and syncing in app. To know luck with updating. I contacted customer service yesterday as my screen kept going black for a few minutes and then blinked in and out of wake mode. Please advise.
Best Answer06-11-2019 03:18
06-11-2019 03:18
Trying doing the restart.
Best Answer06-11-2019 03:27
06-11-2019 03:27
I contacted customer service and they replied the same day. They could see that my data started to update but it carried over from the day before. I was told it would reset itself at midnight as there had been a glitch in the system. So my data was out of whack but they were correct and it did reset at midnight and is back to normal now.
Best Answer06-17-2019 17:57
06-17-2019 17:57
