@RSPLD Welcome to the Fitbit Community! Thanks for sharing your suggestions to better Fitbit Ionic.
I just want to be clear on what you are suggesting. Do you mean you'll like to use speed instead of pace? Choose which of those to use?
Currently, it is possible to set up pace as your top, middle, or bottom stat. You find this option when you go to the settings inside your Run Exercise App under "Customize Stats".
Alternatively, I was making some research on the Feature Suggestions Board and was able to find this idea which is asking to allow to choose between pace or speed. If this is what you are looking for please feel free to add your vote to the idea.
If you would like to suggest a different idea; feel free to search for existent ideas or add an original one.
Hope this helps. Keep me posted! ![]()
@d-vine It's great to see you in the Fitbit Community! Thanks for your suggestions about showing speed in km/h.
I was making some research on the Feature Suggestions Board and was able to find this idea which is asking for the same:
However, the idea was categorized as "Not Currently Planned". I'd recommend checking the ideas to see if it will reflect what you would like to see on Fitbit.
If this doesn't cover what you are asking for; please submit a new original idea so other users can vote fore it.
Hope this helps. Let me know if you post anything! ![]()
that topic closed already.
NEW topic made >>
Ad speed with km/h or mil./h in the exercise run app of Fitbit Ionic
Think it's clear that a little adjustment can be made and make the expensive watch more usefully.
Can you please lobby inside of Fitbit community to make this happen think even you must know this is a must have.
@d-vine Thanks for your reply and for creating that new suggestion.
I already voted for your idea. I do believe it could be very useful to have that for a lot of users. Hopefully, more and more users will vote for your idea to support it. The more votes, the better.
I will leave the link to your suggestion for other users who visit this thread can access it easier:
Tanks again for posting on the Feature Suggestions Board.
See you around! ![]()
