12-20-2018 04:56
12-20-2018 04:56
The buttons all work and it’s syncing but the screen won’t react to anything. It also is restarting itself randomly. It’s still charging with the charger, also. I’ve restarted several times and still the same.
Best Answer12-20-2018 05:00
12-20-2018 05:00
Try a factory reset - settings app and scroll down to About (if you can get there). If you cant then use the button method. If that doesnt fix it you will need to contact Support (link in my signature)
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
12-20-2018 06:09
12-20-2018 06:09
It didn’t fix it. Should I try it again?
