10-23-2020 21:25
10-23-2020 21:25
I've seen numerous posts on here about this happening but have not found any resolution, I've hard reset the device and done everything I've seen online, still nothing, is my ionic just done............?
it will not track steps or do anything anymore...
10-24-2020 12:19
10-24-2020 12:19
I noticed this morning in the app it says there's an update, I'm connected via Wi-Fi and I have my Bluetooth on 98% battery, maybe this new update will resolve the problem, if only the update would work, says cant finish, then wants to switch to Bluetooth. and still nothing, says it still cannot complete. Gets about a 1/4 way on the iconic then goes to update failed, try again over Wi-Fi which I do then goes back to failed, try again over Bluetooth.
I guess it's time to throw this worthless **ahem** in the garbage and by a real fitness device..... Garmin here I come!
All this started from the last update.................... **ahem**!
at least google has real engineers that can write code properly and maybe able to fix this **ahem**!
10-24-2020 12:27
10-24-2020 12:27
I'm already on the version it keeps saying I need to update too .... P . O . S!!
11-03-2020
16:14
12:50
11-03-2020
16:14
12:50
@SunsetRunner It's nice to see you in the Fitbit Community. Thank you for getting in touch about this.
I appreciate the troubleshooting tried and the detailed information shared. I see where your disappointment is coming from.
Since you've tried the recommended troubleshooting, I'd like to share your post with our Support team and they'll be happy to provide the available options. However, please let me know what you're seeing on your Fitbit Ionic display and if it's charging.
Looking forward to hearing back from you.
11-08-2020 14:53
11-08-2020 14:53
