Along with post the Ionic upgrade, I tap on the exercise symbol and it does not switch out to choices.
It just goes back to screen w exercise log.
The other 3 choices on that screen work; alarms, coach and music I don't ever use.
Thanks
PatPasquale
07:28
07:48
10-18-2019
07:28
07:48
@PatPasquale It's great to see you on the Community. Thanks for letting me know that you've updated your Ionic.
I would like you to restart your Ionic and check if after this, you're able to navigate through the exercises' screen.
Best AnswerHello Sylvia
Thank you for your suggestions.
I restarted the Ionic and no changes happened and then I shut it down and no changes happened.
PatPasquale
I did a factory reset and went through that process and this has cleared up and seems to be working now.
thanks
10-22-2019
10:46
07:48
10-22-2019
10:46
07:48
@PatPasquale Thanks for getting back. I'm glad to hear that after performing a factory reset it started working.
