07-29-2018 14:44
07-29-2018 14:44
I let my Ionic run out of battery and now it will not charge. I have had it on the charger for over an hour.
Best Answer07-29-2018 16:17
07-29-2018 16:17
Try following the steps in this help article.
Also try restarting your Ionic by pressing and holding the left button and bottom right button together for 15 secs (until you see the fitbit logo).
07-29-2018 16:53
07-29-2018 16:53
I did that the first time and it did not work but it did an hour later. I hope yours works.
Best Answer07-29-2018 17:04
07-29-2018 17:04
Welcome @Luvmiaggies2 and sorry to hear you are having problems. @N8teGee gave you great advice, which usually will sort things out. Please post back and let us know how your Ionic is working.. Thanks and again, welcome!
Gunny | Richmond, VA (USA)
Ionic Adidas Edition, Versa Special Edition, Aria 2 & Flyer | iPhone & Windows 10
Take a look at the Fitbit Help site for further Assistance & Information.
07-29-2018 17:05
07-29-2018 17:05
If it's still not working, you've got nothing to lose by trying to attempt a full factory (hardware) reset.
Fitbit OS hardware reset.
On the watch, hold all three buttons for about twelve seconds. This will trigger the 2-button hardware restart after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, whilst continuing to hold the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
08-06-2018 18:49
08-06-2018 18:49
Thank you ! I’m up & running!
